Art for art's sake
Sculptor relies on viewer to interpret sculptures, find meaning in art
- By Eric Lundin
- February 10, 2014
If you look at a piece of artwork or a collection of pieces long enough, you’ll learn a little about the artist. You might learn about a social perspective or a political position, and you’ll learn a bit about his technique. Some artists revel in this, but some artists try to remove as much of themselves as possible from their work. At the height of his popularity, Jackson Pollock abandoned the style that made him famous, and toward the end of his career, he stopped giving titles to his paintings and merely numbered them. This sort of thing forces the viewer to take a little extra time and look a little deeper. If the work is truly inspirational, the viewer goes beyond wondering what the artist was thinking and looks inward to find meaning in the work.
This is what Roy Mackey strives to achieve.
130 Percent of Roy
Mackey learned metalworking by buying old cars, doing body work to fix them up, and selling them. Eventually he learned to do the paint work, and along the way he developed an appreciation for cutting, shaping, and finishing steel.
In his free time he took up drawing, mainly faces, and realized that a face could be rendered as a large collection of flat surfaces. Mackey combined his passion for metals with his inspiration to create faces and tried his hand at making one from metal. He liked the outcome and was hooked.
Over the years projects and jobs came and went, and Mackey noticed a frustrating dichotomy. When he had a full-time job he had plenty of money for tools and materials but no time for metalworking; when he had a part-time job, he had plenty of time but little money. A near-fatal motorcycle accident made Mackey realize that life was too short to mess around with a series of jobs that didn’t make him happy, and he became a full-time artist.
A recent project, one he started with more than two decades of artwork under his belt, is “Naked Man,” a 3-D self-portrait in sheet metal. He used small pieces of 20-gauge steel cut from sheet and shaped by hand. The result isn’t just a 130 percent-sized replica of Mackey in midstride; it’s a deceptively formed, perfectly balanced, self-supporting exoskeleton.
“Most people think I hammered the pieces, but I didn’t—just bent them by hand,” Mackey said. “It doesn’t have an armature in the center for support or ballast in the feet for stability or anything like that. When you look at it, you see everything. It’s completely hollow. It’s pretty lightweight and easy to move, yet it’s also well-balanced and stable.”
The Nail Gets Even
Like many artisans, he doesn’t just use tools. He loves tools. He relies heavily on an eclectic collection of antique and vintage tools he has collected over the years.
Tools are such a big part of Mackey’s life that sometimes he sees the world through a tool’s perspective. A hammer—forged, sturdy, and massive—puts a nail where the carpenter wants it, and the nail doesn’t resist. Mackey wondered what would happen if the nail had the upper hand, at least once. The result is “Revenge,” a hammer that appears to be pierced by a nail and bleeding. Mackey liked the result, and a series was born. One has two faces and four claws. Another appears to have had its face split by the nail’s impact. One is combined with a wire brush, which appears to be a Mohawk.
“I made one that has a small towing hook built into it,” Mackey said. “My brother put it on display in his auto parts shop, and once in a while a tow-truck driver sees it and asks what it is, thinking it’s a real tool, but he can’t figure out what it’s for.”
An Introspective Perspective
The bewildered expressions make the tow-hook hammer worthwhile, but they also reveal how Mackey views his work.
“If you held it in your hand, and you swung it side to side a bit to make the hook rotate back and forth on its swivel, you’d wonder what it was for,” Mackey said. “It looks like a real tool, and nobody would expect that someone would spend all this time and effort to make something so useless. In our society, you have to have a reason to do things, and everything follows a logical sequence, and everything has to have an order. When you finally realize that it’s really nothing, you see that it’s really an intriguing piece, and your mind stops trying to figure out what it is. It quiets the mind a bit.”
Eric Lundin
815-227-8262
