Shop technology and 3-D CAD: Cap-offs, springs, and threads
Solid modeling tools are versatile, but not always intuitive
- December 3, 2014
When modeling curved objects, we often create unwanted byproducts such as a flat end face that should be hidden under a rounded end. An example is shown in the upper model in Figure 1. To put a name to this problem, we borrow the term cap-off from Matt Lombard’s SolidWorks Surfacing and Complex Shape Modeling Bible.
One solution to the cap-off is shown in the lower model in Figure 1. This example uses a Loft between the profile of the flat face and a point on a plane some distance from the face. To control the shape, we use a Guide curve.
The result of this loft-as-cap-off has some benefits as well as some drawbacks. The main drawback is demonstrated in the lower model shown in Figure 2. The face of the cap-off does not match the curvature of the handle body, even though it is tangent and in contact with the handle. The consequence is that there is a distinct line around the cap-off.
The upper model in Figure 2 demonstrates a different solution to the problem—use of a Surface-fill feature instead of a Loft. This cap-off was inspired by an idea in Lombard’s book. The ability to match the curvature of the main handle body results in an excellent blend. Additionally, the setup is somewhat easier than that for the Loft solution. To compare these cap-offs, we’ll dig into some of the details of the loft-cap-off first.
Looking Into the Loft
Figure 3 is a screen shot of the Property Manager for the Loft feature. This specific loft is defined between two sketches. The sketch that starts the loft is an exact match of the face to cap-off. The other sketch contains a sketched point that controls where the loft ends. An experienced CAD jockey can construct these sketches and define these lofts in several different ways. All CAD methods have merits. The prevailing design constraints generally help to select the best method.
A CAD trick used here is to multipurpose the sketch with the point. That sketch (3DSketch7) also has an arc that controls the shape of the loft. Without this guide curve, the loft would try to form a cone to a sharp point. With the guide curve, the loft blends in a more pleasing manner.
Of note at the bottom of the Property Manager shown in Figure 3 is the option to Merge result. If this option were not checked, this loft would create a solid body separate from the solid body of the handle. Multibody versus single body is a concept that is often regarded as mundane in solid modeling, as it should be.
In review, to set up this loft we needed a sketched profile to start, a sketched profile to end, and a sketched guide curve. We used a 3-D sketch to create both the guide curve and the end point sketch.
As a side note, using a sketch for multiple purposes like this might be efficient, but the next CAD jockey that comes along to edit this model will have to spend some time sorting out where the required setup items are hidden. A similar sin of this nature is the trick of using a temporary axis to constrain a sketch. When the axis is invisible, the sketch remains constrained. You know why, but will the next person who edits this model think to turn on invisible things?
Focusing on the Surface-fill
Turning to our example of a cap-off solution using a Surface-fill feature, Figure 4a is a screen shot of our setup of a plane some distance from the end of the handle. We use that plane to sketch the guide curve for the Surface-fill feature-to-be. Figure 4b shows the sketched guide curve. This is where we pause in awe of Lombard’s insight: Anything can be a guide curve—even a straight line!
In our example, we are modeling the little bit of flatness that results, as this end of the casting would be sanded and polished. Myriad possibilities for guide curves are possible; Lombard’s cap-off solution, however, is versatile.
Figure 5 shows the Property Manager for Surface-fill, whereas Figure 3 shows that for the Loft. As shown in Figure 5, our Surface-fill needs a Boundary. The edges around the end of the handle were selected.
Note that all edges match Curvature, not simple Tangency. This curvature option results in a very good-looking cap-off.
As with the Loft in Figure 3, the Surface-fill in Figure 5 has an option for Merge result. In the case of the Surface-fill, this option is merging a surface into a body—a wonderful bit of convenience. To accomplish this otherwise, we would need to knit surfaces and try to form a solid body from the result. Knitting surfaces and forming solids is a topic for another day.
In keeping with the nonintuitive straight-line guide curve, the CAD jockey can use the option for Reverse in the Surface-fill, as shown at the bottom of Figure 5. The author believes this should be labeled “Hail Mary!” instead. If the Surface-fill fails, try the other setting of Reverse, and it might work. Reverse probably makes more sense if one were to study the math that is underlying this very useful surfacing tool.
Examining the Bill of Materials
The model for the handle we’ve been reviewing so far is part of a hair clipper design as shown in Figure 6. The table that appears below the model is a preview of the Bill of Materials. Note that this table corresponds to the components inserted into the assembly as shown in the Feature Manager to the left of the graphics window.
Last month (“Shop technology and 3-D CAD: Some boundaries in solid modeling,” Precision Matters, The FABRICATOR, October 2014, p. 66), we began working our way through the bill of materials to examine the models for each line item. Not following any particular order, we reviewed the models for the blades and wing nut and noted that conventional solid modeling techniques achieved good results. The blade cover was best modeled using a combination of surface modeling and solid modeling techniques. We called that hybrid modeling.
To complete our tour of parts, Figure 7 shows the four components that give spring action to the handle: spring cap, spring, spring actuator, and ball pin.
The ball pin model shown in Figure 8 is modeled as a Revolve of a Sketched profile. The merits of Revolve, rather than an alternative technique such as a stack of extruded cylinders with fillets and chamfers, include:
- Faster rebuild time
- Shorter feature history
- All features in a single, easy-to-edit sketch
- Suitable for the goal of the model, which is a spherical push-end
- Fewer mouse clicks and thus a speedier CAD jockey
There is not much difference in terms of the CAD methods used to create the ball pin and the spring actuator. Both are easy to model as Revolves. The spring actuator is visible in Figure 7 and presses into the end of the spring to provide an engagement socket for the ball pin.
Should the ball pin and the swing handle be modeled as an assembly instead of as stand-alone parts? This is a rhetorical question with a dichotomy of answers.
Yes. And those two parts and their assembly should be given part numbers. Assembly documentation will include an exploded view and instructions for pressing the pin into the casting.
No. A subassembly of these two components is not really needed. They can co-exist at the top level of the BOM for the purposes of a visual prototype. Of course, when creating Motion Studies, it is sometimes handier to select subassemblies instead of groups of parts.
Regarding the modeling methods used for the spring, it is basically a Sweep with Cut-extrudes to flatten the ends. The cute trick is with the helix that drives the sweep.
The Property Manager for the sweep’s helix is show in Figure 9a. Of particular note in Figure 9a is the Variable Pitch of the helix as used in manufacturing a flat-ended spring.
The spring’s Sweep feature setup is shown in Figure 9b. In this example, the spring’s wire is round, so the profile sketch is a simple circle noted as Sketch3. The helix was defined to match the outside diameter of the finished spring. This decision was made for the convenience of matching the spring’s size to the bore in the handle.
Last, we visit another method of modeling swept-cut threads. Figure 10 shows the model for the spring cap. Instead of using a helix to create the path for the cut, this model uses a path that is defined by an interference curve between the outside diameter of the thread and a swept surface.
The swept surface feature has an option to twist along its path. In this example, the path is a line along the axis of the cap. It is easy to set the number of twists to match the target thread pitch.
This twisted swept surface trick has a slightly faster rebuild time than the helix. The helix has the convenience of variable pitch setup. Let us know which you feel is better.
